Drilled through a cable!
dinx67
by dinx67 » Sun Mar 01, 2009 9:15 pm
In the middle of fitting a new kitchen and managed to drill through the cable (buried in the wall) that leads to the cooker on/off switch. Husband says he can fix it by joining the cable but I'm not so sure. Any advice or information would be much appreciated, thanks.
by stoneyboy » Mon Mar 02, 2009 10:04 pm
dinx67,
Repair is very unwise. With luck the cable will be enclosed in conduit or sheathing and can be replaced with new. It would be wise to get a minor works certificate for this.
rosebery
by rosebery » Tue Mar 03, 2009 12:39 am
The cable must be replaced.
moggy1968
by moggy1968 » Tue Mar 03, 2009 9:04 am
If the cable is buried in the wall (rther than in conduit or behind a stud wall) then it can be repaired, although as above this isn't ideal, as the repair can fail over time. on any circuit the weak link is joints. Really this should be done by an electrician to ensure it is done correctly. It's quite a common call out!
It will involve making quite a large hole in your wall though, probably around12 inches long and 4 inches wide.
lock up your husbands tool box!
It is currently Sun Jan 19, 2025 8:20 am
