Coving size match
diymum
Coving size match
by diymum » Thu Mar 05, 2009 9:06 am
I have a piece of missing coving to replace due to reorganising a door opening. I do not know whic bit of existing coving to measure in order to find a match. Is it the diagonal or the straight edge? It easures 3.75 inches on the straight edge and marginally under 5 inches n the diagonal.
Locl diy suppliers do not seem to have that size.
kbrownie
by kbrownie » Thu Mar 05, 2009 12:01 pm
if you can just put a bit of board across section draw a template of it and take that to merchant to insure you get correct size
kb
rosebery
by rosebery » Thu Mar 05, 2009 9:41 pm
Coving comes in two sizes. 100mm and 127mm. 3.75" is too small for 100mm but 127mm and 5" are spot on the same size.
Its a reasonable expectation therefore that you want 127mm coving. You won't get less than a 2m length but heres the real issue. The curve of the profile will vary from manufacturer to manufacture so you may not get an exact match.
So KBs advice to make a template is a very good plan.
It is currently Sun Nov 24, 2024 7:33 am
