Socket close to wash handbasin in bedroom
slh
by slh » Fri Mar 06, 2009 11:05 am
Dear DIY Doctor,
I have a wash handbasin in my bedroom that is very close to a ring main socket. I wish to replace the basin with a new one that sits on a cabinet in a position where the ring main socket would be enclosed behind the cabinet. If I resite the socket, what is the minimum distance from the wash handbasin the new position must be, please?
If instead I choose not to resite it, does it have to be removed, or can I blank it off with a blanking plate, assuming that one with connections is available that will allow the integrity of the ring main to be preserved.
Yours,
slh
kbrownie
by kbrownie » Fri Mar 06, 2009 4:13 pm
Hi slh,
you would think there would be some regulations that offered zones around a wash basin where socket-outlets are not permitted, similar to the ones for bathrooms and showers.
It is recommended that the socket-outlet is at least 300mm from the basin you could put a blank face plate on it. I would want it to be protected suitable from any potential water ingress though and still 300mm from basin.
Hope this helped
KB
slh
by slh » Sat Mar 07, 2009 6:40 pm
Dear KB,
Thank you for your advice; it was very useful.
slh.
It is currently Sun Jan 19, 2025 5:13 am
