help
7 posts   •   Page 1 of 1
heating09
help
by heating09 » Fri Mar 06, 2009 2:57 pm
oil boiler on balanced flue
increase the air on the burner to obtain the correct combustion reading
but increasing the air seems to blow the flame out
any suggestions on how to remedy or why this happens
Steve the gas
by Steve the gas » Sat Mar 07, 2009 4:33 am
Your getting flame lift - too much air.
Are you qualified?
If not, get an Hetas person in?
by stoneyboy » Sat Mar 07, 2009 5:07 pm
heating09,
The equipment you are using to test the combustion gases is giving the wrong reading.
heating09
by heating09 » Sat Mar 07, 2009 9:42 pm
yes qualified, why is the flame blowing out????
nothing to do with meter,
had to leave it burning rich with high co
why cant i increase the air with out it tripping out
nozzle may be ???
any suggestions
by stoneyboy » Sun Mar 08, 2009 4:25 pm
heating09,
Have you checked the pressure to the nozzle, is it set as in the operating manual? Have a look in the manual and see what nozzle is recommended. If you are using a hollow pattern nozzle, try a solid one and vv.
When you now refer to "tripping out" do you mean this or that the flame becomes unstable and blows out.
heating09
by heating09 » Mon Mar 09, 2009 8:12 am
nozzle pressure ok
flame begins to blow out every 5 mins or so when correct co2 is reached
flame only stabilises when burning rich i.e 13% co2
this isnt any good cause the co then goes to 300ppm
by stoneyboy » Mon Mar 09, 2009 9:24 pm
heating09,
Have you tried a new nozzle? Is the correct size nozzle fitted ie one which matches the boiler. Check the manual and see if the burner has been replaced with one which is too big for the boiler. Have you checked the relationship between the nozzle and the air spinner plate does this match the spec in the manual?
