Dot & Dab Marks Visible Through Plaster & .........H
6 posts   •   Page 1 of 1
charliesdad
by charliesdad » Mon Mar 09, 2009 11:18 am
I have had an outside wall plastered with the Dot & Dab method, & now after about 6 months the black areas where the dot & dabs were applied are clearly visible through the plasterboard, plaster & 2 coats of paint. The wall now looks like it has a dose of very large black spot - Please help.
kbrownie
by kbrownie » Mon Mar 09, 2009 3:13 pm
did you external wall have damp problems?
KB
charliesdad
Black Spot Problem ctd...........
by charliesdad » Wed Mar 11, 2009 2:18 pm
The wall was fine for about a year, then all of a sudden, these dot & dab patches can be seen. The wall was initially an outside wall of a drive thru carport, with a bedroom extension above. Both ends of the carport were then glazed to form a room. Radiators provide the heating, so I know it is not condensation. I could understand if the dot & dab was being used to bridge the damp, however the walls surface shows no sign of damp at all.
Any Ideas....?? - Thanks for your help in advance.
kbrownie
by kbrownie » Wed Mar 11, 2009 8:08 pm
Was this wall a single skin or a cavity wall. If single skin wall it should have been treated prior to fixing boards.
KB
charliesdad
Black spot - Dot & Dab problems........
by charliesdad » Wed Mar 18, 2009 8:49 am
OK thanks, I believe the wall is single skin, there is however a second wall, but its not a closed cavity. this second wall belongs to next door but the gap is only about 2 inches.
Assuming I have to take it back to the brick - what do I have to treat it with, & is there an anti damp/fungal additive for the dot & dab mix. ??
kbrownie
by kbrownie » Wed Mar 18, 2009 4:03 pm
have a look at projects page "wall linings" may be helpful
KB
It is currently Thu Nov 28, 2024 12:43 am
