when to get a plumber in
jond
by jond » Mon May 21, 2007 9:11 pm
Hello doctor just need some advice on when is the best time to get a plumber in to connect my gas hob as the pipe which needs to be run has got to come from my old boiler cupboad through a stud wall and then run along the wall for about a metre i am doing the kitchen myself and dont know wether to put the carcuses in first then get him in or get him in before that and just woundered how its connected up is it a copper pipe all the way to the hob or can it be a copper pipe of a metre then a flexible hose your advise would be appricated as i have to book a plumber up cheers
thedoctor
by thedoctor » Wed May 23, 2007 8:11 am
The easier the job is for the plumber the less it will cost. Get him in before you build any walls to "first fix" which means running all the pipework to the correct place and get him to include in his price a couple of hours for coming back to connect up when you have done the rest and the appliances etc are in place,.
It is currently Fri Nov 22, 2024 4:16 am
