Blistering on new ceiling.
PaulFarrugia
by PaulFarrugia » Tue Mar 10, 2009 12:44 pm
Hi there.
I had a new ceiling put up about a month ago and after a week started to paint emulsion on to it. The first coat went up fine, but the 2nd coat has started to blister. The guy who put the celing up said i could just paint on it but now i realize i may have needed to put sealer or primer on the plasterboard before. I guess my questions are how do i stop the blistering and can i put sealer on top of paint or do i have to take all the paint off?
Thanks in advance!
Paul
by stoneyboy » Thu Mar 12, 2009 10:57 pm
PaulFarrugia,
Suspect you did not water down your first coat, if this was the case you will need to scrape off the first coat - it should come off easily - use a filler knife.
end.
rosebery
by rosebery » Thu Mar 12, 2009 11:32 pm
Basics first.
Are you painting plasterboard or skimmed plasterboard?
PaulFarrugia
by PaulFarrugia » Fri Mar 13, 2009 10:04 am
Cheers Stoneyboy!
It is currently Wed Nov 27, 2024 10:29 am
