Will I need a Durgo
itsme
Will I need a Durgo
by itsme » Fri Mar 13, 2009 9:14 pm
Hi peeps.
There are two cubicles with toilets. The wall shall be knocked down and I have to remove one of the toilets to place a bath. Both toilets have waste in the floor.
I was thinking of digging down and using a 1 & 1/2" reducer. I would bring the pipe up and place the reducer flush with the floor. The 1 & 1/2" would then be used as the waste for the new bath.
Can I do this without venting the removed toilets waste with a durgo?
plumbbob
by plumbbob » Sat Mar 14, 2009 11:21 pm
It is difficult to be sure without seeing the installation, but if the existing toilets do not have a vent or dirgo, then the alteration will not require one either. Generally each property requires only one vent which is positioned at the head of a drainage run, the furthest from the main public sewer.
It is currently Wed Jan 01, 2025 8:25 am
