10mm cable through loft insulation.
Nonplumber
by Nonplumber » Sun Mar 15, 2009 2:51 pm
Route from shower unit to switch goes up, across loft and down again. Loft is insulated 100m with boards. Best/correct way to route cable? If it passes through insulation how much space is required within the insulation. If it is clipped at the top of joist sides is it ok to put wooden boards back in position with insulation kept 50mm away from cable?
kbrownie
by kbrownie » Sun Mar 15, 2009 9:19 pm
That's fine if clipped direct and not covered by insulation it will not need to be derated.
KB
by sparx » Sun Mar 15, 2009 9:32 pm
As I said to your previous post, ask the mug...er leckie who is going to sign off on your work how he wants it run,
It is currently Sat Nov 23, 2024 3:15 pm
