Internal Overflow for Old Cistern?
Punx0r
by Punx0r » Tue Mar 17, 2009 11:11 pm
Greetings all, I'm hoping you can help me solve a problem for my dad:
Having recently extended his bathroom, the toilet (old thing, wall mounted cistern, but at normal height with a flush handle, not overhead with a chain) has gone from an external overflow to no overflow.
Some research on the internet confirmed that you can now get syphons with an overflow built in. Unfortunately, the shortest one commonly available (8 inch, I think) has the overflow level about 2 inches above the normal water level in the cistern (although it does fit ok and flush okish).
The toilet clearly needs a working overflow. Can anyone tell me if a shorter syphon is available to work with older, shallower cisterns? Or is there a downpipe available that incorporates an overflow to dispose of excess water via the toilet itself?
Any help would be greatly appreciated!
Anthony
plumbbob
by plumbbob » Wed Mar 18, 2009 8:35 pm
Have a look at this.
http://www.awin1.com/awclick.php?mid=12 ... Handle-Kit
There are various different models on the market that may do what you need.
There are, as far as I am aware, only two heights of syphon on the market, and the 8" is the shortest. Older cisterns tend to be wider than newer models so the water in them is shallower which creates the problem you mention as they were never designed to have internal overflows. It was against water regs up until recently. You can of course lead the overflow away to a bath trap for example.
It is not possible to connect any separate mechanism to a syphon to act as an overflow because it would stop the syphon from working.
Punx0r
by Punx0r » Thu Mar 19, 2009 7:43 pm
Many thanks for the reply :)
The screwfix looks like it could do the trick if it's adjustable over a wide range of water-height.
Unforunately, the bath is on the other side of the room.
The cistern has an outlet for an external overflow (currently blanked off), it was this I was wondering if it could be plumbed into the toilet bowl, rather than adapting the syphon.
plumbbob
by plumbbob » Thu Mar 19, 2009 11:47 pm
With the overflow height, you just cut it off at the height required.
I can't see how the overflow can be connected into the pan anywhere. I assume the toilet is a low level with a "L" shaped flush pipe? Well, anyway, if you tried to connect the overflow into the flush pipe, it would stop the syphon and the toilet just wouldn't flush at all.
As I see it, there just is no other choice other than replacing the cistern. Is it plastic? they aren't necessarily that expensive you know?
Punx0r
by Punx0r » Sat Mar 21, 2009 11:30 pm
The cistern is ceramic. I don't know its exact age, but it's rather old, it goes with the cast iron bath and he got a period hand basin and pedestal to match. He's a bit of fan of older stuff.
I think that adjustable syhpon will be just the ticket, thanks :)
It is currently Tue Dec 03, 2024 12:34 am
