Damp uneven concrete floor - should I screed ?
highlandhouse
by highlandhouse » Wed Mar 18, 2009 10:57 am
Hi all. I have a living room where half the floor is sound level concrete, the other half is older, lower - ranging from 5mm to 15mm, and uneven. Also its damp in patches. I was planning to screed it level with the good floor. Is this a good idea and if so how can i rid it of damp given that I will need to use such a thin screed ?? I plan to lay carpet on top. Please help !!
Many thanks....... :D
by stoneyboy » Wed Mar 18, 2009 9:26 pm
highlandhouse,
You should cure the damp problem before levelling the floor, this may well mean that you will have to dig up the floor, incorporate a DPM and relay the floor.
It is currently Sat Jan 11, 2025 4:49 pm
