Where do I begin
Post your questions and get answers on the subject of setting out
gerloo
Where do I begin
by gerloo » Fri Mar 20, 2009 8:13 pm
I have bought a house in Bulgaria and have designed an extension. I need help in calculating foundations and underpinning.
How deep should foundations be? How much ballast/cement etc will I need for the foundations. The area of the extension is 85 sq m.[size=18][/size] :?
I want to know how much stuff I will need because I want to know if I am being ripped off.
Gerloo
measurements
by welsh brickie » Sat Mar 21, 2009 4:01 pm
if you want to calculate concrete
length x breath x depth
say trench is 600mm wide and depth of concrete is 200mm thick and its 25metres long
calculate 25 x .6 x .2 that will give you per cubic square metre.
Also its 2.2 tonnes of concrete to a cubic square metre
hope this helps
gerloo
by gerloo » Sat Mar 21, 2009 7:23 pm
Thank very much Welsh Brickie. You have been a big help.
It is currently Fri Jan 31, 2025 12:27 am
