Leaking Monobloc
Simon J
Leaking Monobloc
by Simon J » Tue May 22, 2007 2:05 pm
I recently bought a glass dish monobloc tap, however it seems to be leaking inside as water is running down the fixing bolts. I have checked and it does not seem to be the pipes. Has anybody got any ideas on how I can stop the leak, or where it might be coming from?
by htg engineer » Thu May 24, 2007 5:32 pm
check tails are in correctly (not crossed) and that they have rubber seals on that do not look damaged. Could it be water getting under the tap ? there should be a rubber seal between the sink and the tap.
It is currently Mon Dec 23, 2024 5:25 am
