Air spa venturis
6 posts   •   Page 1 of 1
Dibble
Air spa venturis
by Dibble » Mon Mar 23, 2009 3:23 pm
Has anyone any idea where I can buy new venturis for my air spa bath? They must have non-return valves.
rosebery
by rosebery » Mon Mar 23, 2009 8:36 pm
Can you be a little more specific.
Have you tried contacting the manufacturer of the spa?
Dibble
by Dibble » Tue Mar 24, 2009 3:02 pm
Bought a new bathroom ages ago and the bath was fitted with an air spa system. The air came out of venturis fitted in bottom of bath. When I subsequently changed the bath, I bought new venturis as the old platic ones had had it. Unfortunately the new metal ones did not have non-return valves so water sits in the pipes until next time the spa is used. This can get a bit smelly. I have a new bath to fit and want to fit the spa system to that but need new venturis.
rosebery
by rosebery » Tue Mar 24, 2009 8:33 pm
Have you tried contacting the manufacturer of the spa??????????
Dibble
by Dibble » Wed Mar 25, 2009 11:51 am
[quote="rosebery"]Have you tried contacting the manufacturer of the spa??????????
Cheers[/quote]
Firm I bought suite off originally has closed, no name of maker of Airspa system anywhere, so can't contact manufacturer. I have googled bits that I need and sent emails to various places making enquiries but no reply as yet. When I drilled the present bath I used a glass/tile drill bit. 12mm. Is there anything better out now for drilling acrylic baths?
rosebery
by rosebery » Thu Mar 26, 2009 7:32 am
"Firm I bought suite off originally has closed, no name of maker of Airspa system anywhere, so can't contact manufacturer."
Oh.
"I have googled bits that I need and sent emails to various places making enquiries but no reply as yet."
Tried this one - its in Oz. Google "spaparts.com.au/category13_1.htm"
You could always start afresh with a new kit as well.
"When I drilled the present bath I used a glass/tile drill bit. 12mm. Is there anything better out now for drilling acrylic baths?"
Yes use one of these:
http://www.awin1.com/awclick.php?mid=12 ... &source=aw
It is currently Sat Nov 23, 2024 12:00 am
