CONNECTIONS TO RCBO
BAUERJAN
CONNECTIONS TO RCBO
by BAUERJAN » Tue May 22, 2007 3:17 pm
Hello everybody.
I have a Moeller RCBo.
I am unsure about the connections.
There is a flying neutral lead.
There is no earth lead or connection.
Has anyone any info re connections.
I am using it to feed tha hob in kitchen
It is rated at 32A
by sparx » Wed May 23, 2007 12:31 am
OK leaving aside the fact that you shouldn't be doing this yourself......
The RCBO gets its live from busbar connection the neutral fly lead goes to neutral bar where your circuit N would normally go & L & N to circuit go into two terms. so marked on RCBO; your circuit E goes to normal place in E bar.
the L goes a long way down into RCBO to the outgoing term, so make sure wire firmly in term!!!
Regards SPARX
BAUERJAN
RCBO CONNECTIONS
by BAUERJAN » Wed May 23, 2007 11:16 pm
Many thanks SPARX
It is currently Thu Dec 12, 2024 4:50 pm
