Distance between feed's
agk1
by agk1 » Thu Mar 26, 2009 12:03 pm
Hi, am looking to take a feed off my cold water but easiest/closest is 6" [b]before[/b] the feed to my boiler and about 6' from house feed which has a good pressure, the feed is for a outdoor tap which will not be in constant use, is this too close?
plumbbob
by plumbbob » Thu Mar 26, 2009 9:04 pm
If you are talking about high pressure cold mains for a traditional outside tap, the connection can be made anywhere. The boiler position is irrelevant.
agk1
by agk1 » Fri Mar 27, 2009 12:04 am
Yes, the mains come's in and then feed's the boiler and it was ahead of the boiler feed I was going to tap in so I think you have anwsered my Q.
Cheer's Plumbbob
It is currently Fri Dec 27, 2024 11:48 am
