by htg engineer »
Fri Mar 27, 2009 5:10 pm
When it reaches 3+ bar the PRV will open and water will be discharged via the PRV pipework to outside, the normal cause for this is that the expansion vessel diaphragm has stretched or split.
The expansion vessel needs re-pressurising or replacing. Press the schraeder valve to see if there's any air or water there.
Air - re-pressurise with a foot or hand pump to 1bar
Water - renew vessel.
htg
