immersion heater
danny s
immersion heater
by danny s » Sun Mar 29, 2009 6:01 pm
what action should be completed before i start working on my replacement of an electric immersion heater :cry: do i get a electrian to look at it first or what?
rosebery
by rosebery » Mon Mar 30, 2009 12:36 am
Is it powered via an FCU or plugged intoa socket?
The IH should be fed via a 20A double pole switch which you can turn off. It should be visible to you whilst working on the heater so that you can be certain noone has turned it on again whilst your back was turned.
If you can't see it go to the CU, flip the circuit OFF and put a DO NOT TURN ON notice on it!!
ALWAYS "test for dead" - even if you think you've done what you need to do. Take note of the way the cable is connected to the heater before removing the wires.
Get yourself a proper Imersion Heater spanner BTW - box type is best.
HTH
If
Chesham Kitcxhens
Re: immersion heater
by Chesham Kitcxhens » Tue Mar 31, 2009 7:48 pm
[quote="danny s"]what action should be completed before i start working on my replacement of an electric immersion heater :cry: do i get a electrian to look at it first or what?[/quote]
don't forget to part empty the tank.
Adrian
Chesham Kitcxhens
by Chesham Kitcxhens » Tue Mar 31, 2009 7:49 pm
Adrian
It is currently Fri Dec 27, 2024 12:51 am
