LOOSE TOILET SEAT TOP
daisuki
by daisuki » Thu Apr 02, 2009 11:09 am
I have a wooden toilet seat, the bottom portion is secure and ajustable via the "wing nuts" underneath.
However the top/lid is loose and i cannot see where to adjust it.
Could someone please be kind enough to help.
by stoneyboy » Thu Apr 02, 2009 9:50 pm
daisuki,
You will probably need to remove the wing nuts, lift off the seat and lid as an assembly and you can then get at the fixings to tighten everything together.
daisuki
by daisuki » Fri Apr 03, 2009 3:07 pm
[quote="stoneyboy"]daisuki,
end[/quote]
Many thanks for the info, it was a loose screw, that i could only see when i removed the seat.
It is currently Tue Dec 03, 2024 12:22 am
