Adding Antifreeze to a Static caravan Central Heating
Doneroaming
by Doneroaming » Thu Apr 02, 2009 3:18 pm
My boiler is a combi boiler and I drained the central heating by mistake
and wonder how I can add new antifreeze to it.
I have one radiator in the bedroom, toilet/shower,small bedroom,Lounge.
Someone said it needs Sentinel Antifreeze but how much and are there other Antifreeze's one can use.
Any Advice will be welcome :oops:
missionary
by missionary » Sat Apr 04, 2009 7:50 pm
This may or may not help !
I have fitted a c/h system in my canal narrowboat which works on a thermo syphon principle (no pump). It runs from a Kabola oil fired boiler.
It has 28mm pipe all round and one radiator about 25ft from the boiler 'uphill' with a vent at the top end of the rad to an expansion tank feeding the bottom of the same rad.
This is protected by 25% ehtylene glycol car antifreeze. It has run faultlessly since November 1998. All my friends who have similar systems use this to antifreeze their boat systems 12 months a year. HTH
mish
Newbee
by Newbee » Mon Apr 06, 2009 9:18 pm
Hi there, I've a static which I'm in the process of plumbing in (no central heating) but the tip with antifreeze I have with static's is to put some in your toilet pan over winter instead of trying to empty it, our site is closed for 5 months over winter.
Doneroaming
by Doneroaming » Wed Apr 29, 2009 10:23 am
[quote="missionary"]This may or may not help !
mish[/quote]
Thank You for your Reply :D
It is currently Fri Nov 22, 2024 6:44 am
