Cavity lean mix
Dorset
Cavity lean mix
by Dorset » Sun Apr 05, 2009 10:19 am
I have to put a lean mix into the bottom of the cavity 225mm below DPC.
I am unsure on what a lean mix is. is it sand and cement or ballast and cement and what ratios are used.
Your help once again is mucho appreciated
elwood
by elwood » Thu Apr 09, 2009 12:12 pm
When ordering ask for concreting ballast.
A lean mix is a dry weak mix
Bye
It is currently Fri Jan 10, 2025 4:50 am
