Flat Roof Ventilation
ross1theboss1
by ross1theboss1 » Mon Apr 06, 2009 2:55 pm
Hi and help, I`m fitting a flat roof on to my daughters new extension using the cold roof system with kingspan between the joists.
The problem i have is to keep an air flow above the insulation i need the name of a product i can buy for the vent escape against the wall.
Another factor is that the rafters fix to a wall plate so the nearest this product can fix to is 50mm from the wall.
help will be appreciated.
andrew
helpar
by helpar » Sat May 23, 2009 10:55 am
Hi Ross
I am doing a very similare project, need to insulate a garage roof
which ajoins the house and joists run back to the house .
Would like to use a cold roof system, but need some way of
venting the airgap where roof meets house.
Did you find a product?
Regards
Helen
helpar
flat roof venting
by helpar » Sat May 23, 2009 11:21 am
Hi Ross
Just found aproduct by Glidevale Google "glidevale.com"
flat roof ventilation terminals.
Helen
TheDoctor4
Local help at hand!
by TheDoctor4 » Fri Jul 09, 2010 9:56 pm
Find trusted, insured and vetted tradesman local to your area. Visit the DIY Doctor Find a Tradesman page: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Sat Jan 04, 2025 1:53 am
