Need to Pull 2 Fuses to Break Circuit
MuddyFunkster
by MuddyFunkster » Tue Apr 07, 2009 1:43 pm
I have just move into a bungalow that was built 50 years ago and extended in the early 70s.
Last night I discovered that in order to isolate the power from the sockets you need to pull two 15Amp fuses.
If you pull just one the sockets stay live, it does not matter which one you pull.
Therefore the two fuses are in parallel, this seams wrong - is it?
kbrownie
by kbrownie » Tue Apr 07, 2009 6:14 pm
MuddyFunkster,
It is wrong you have Ring final circuit and someone has decided to run each leg of a different fuse/breaker!
This a not safe or good method :shock:
It needs to be in one fuse/breaker only
What size cable is it and what area does the circuit cover in square meters?
Then we can advise correct fuse size.
KB
kuzz
by kuzz » Tue Apr 07, 2009 6:56 pm
very wrong and very dangerous. It could be very simple to fix, or it could be more complex, either way you'll need an electrician with a set of test equipment.
rosebery
by rosebery » Tue Apr 07, 2009 9:50 pm
It sounds to me as though a PIR would be money very well spent on your electrical installation.
It is currently Fri Nov 22, 2024 8:11 am
