Priming MDF
diynewbiesos
Priming MDF
by diynewbiesos » Thu Apr 09, 2009 10:28 am
HI all,
My brotherinlaw made a fish tank stand and hood for us the cabinet doors and hood panels had to be made with MDF so as not to warp, I was going to prime it but was told a few coats of paint was all that was needed WRONG, after having quite a few coats of paint it looks streaky and horrid. The fish tank and stand is 6ft so its a lot of messy paint work to look at lol :lol:
My question is can i use a primer on it on top of the paint thats already on? would that do the trick?
Thanks in advance.
TheDoctor4
Re: Priming MDF
by TheDoctor4 » Mon Jun 02, 2014 12:06 pm
In all honesty it is probably best to rub it all down and start again, using the correct primer/sealer at the base stage and then a top coat once primer is dried. We do have a project page that walks you through the process here: https://www.diydoctor.org.uk/projects/mdf.htm
Kind Regards
The DIY Doctor Team
Cook85
Re: Priming MDF
by Cook85 » Thu Jun 05, 2014 2:13 pm
I'd just sand it down, not to necessarily remove all the paint, but then put a good primer on and re-paint it. Bear in mind gloss paint needs to be spread quite thinly so that it doesn't streak.
It is currently Sat Nov 23, 2024 5:01 pm
