What sand for a concrete mix ?
ssjdc
by ssjdc » Sun Apr 12, 2009 4:28 pm
I need to lay a 6in slab for a hot tub and would like to use the materials I have lying around. I have plenty of 20mm aggregate and soft sand. Normally sharp sand is used of course, but would it cause a problem if I used soft sand ? I will also be putting in a reinforcing mesh.
rosebery
by rosebery » Mon Apr 13, 2009 10:54 pm
You know the answer already because its in your post. Building sand doesn't make good concrete.
It is currently Sun Dec 22, 2024 11:35 pm
