Garden Shed
Joyce Cahill
Garden Shed
by Joyce Cahill » Mon Apr 13, 2009 9:08 am
I am transforming a garden shed in to a playroom for my grandchildren. In one corner some of the wood has rotted (about 10" square). Is there any form of sealant that I can use to pour into this area to harden the timber and stop the rot before I fill the hole with filler.
by stoneyboy » Sat Apr 18, 2009 3:44 pm
Joyce Cahill,
Ask for wood hardener at your local DIY store, they should supply you with a tin of clear, highly flammable liquid which will strenghen the rotten timber.
If you want to stop the rot you will have to use a liquid with nasty chemicals in it - I would not recommend it for a playroom.
rosebery
by rosebery » Sat Apr 18, 2009 3:49 pm
Yes - wood hardener!
Chop out as much rotten wood as possi first though.
It is currently Fri Jan 10, 2025 3:35 am
