granite worktops
7 posts   •   Page 1 of 1
Jeff007
granite worktops
by Jeff007 » Mon Apr 13, 2009 12:45 pm
We have decided to build our new house. There is not much space and so I have converted the kitchen as a part of the dining room. I want to place a worktop which will work as a breakfast table. Will granite work well?
rosebery
by rosebery » Mon Apr 13, 2009 10:41 pm
"Will granite work well?"
Why not?
clarawatson
by clarawatson » Tue Apr 14, 2009 7:25 am
Granite will be perfect. You can shape it according to your wish. Besides it will look great as an overhang.
Agandm
by Agandm » Wed May 12, 2010 12:19 pm
No doubt you have this sorted by now, but for others looking for similar advice:
30mm is the standard thickness for granite worktops. At this thickness, it should not be expected to overhang more than 300mm unsupported.
You should make a framework with the legs at each corner, rather than having each leg isolated.
Thanks.
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Mon Jun 28, 2010 9:33 pm
Discover how easy it is to find vetted and insured tradesman local to your area with the help of DIY Doctor. Visit our Find a Tradesman area: https://www.diydoctor.org.uk/find_tradesmen/
kaylee
Re: granite worktops
by kaylee » Thu Oct 27, 2011 1:49 am
it is certainly true that granite is the most commonly used stone for worktops because it has natural colours and patterns that make it generally appealing to look at, especially the finished look. Each slab of granite is unique, with random and inconsistent patterns which add to the attribute of the stone and a range of colours that reveal the region and geological conditions that created it. Granite also has strong functional advantages that really come to the fore when it's used as a kitchen worktop, a role that requires it to take plenty of physical punishment. It's highly durable, it doesn't scratch or burn - it's heat resistant - and it keeps its colour. This gives it the edge over other worktop surfaces like laminate and wood.
Chris Wyatt
by Chris Wyatt » Thu Nov 10, 2011 7:48 am
Granite is the best choice for kitchen. Granite available in many color, it doesn't scratch and burn. So go for it.
It is currently Sat Nov 23, 2024 1:29 pm
