mounting 8mm bath screen on stud wall
brokenbetty
by brokenbetty » Mon Apr 13, 2009 9:14 pm
I have been given a second hand bath screen. It's the same style as this:
Google "clickbathrooms.co.uk/pd-BTHSCR001AC.htm"
but 8mm not 6.
It's very heavy, and it's supposed to go on a stud wall. We plan to build the wall using 2x3 studs, but use a 2x4 stud where the bath screen will be to take the extra weight. Will that be safe to mount the screen or do I need to do something else?
Liz
rosebery
by rosebery » Mon Apr 13, 2009 11:27 pm
Bath screens like this are a dead weight when you lift them but I wouldn't bother using a larger piece of timber. The piece you fix onto the wall will only be held up by 3 or 4 screws anyway by design.
By the time you've boarded and tiled you'll have a fairly substantial wall to which to fix it. You'll be fine.
brokenbetty
Re: mounting 8mm bath screen on stud wall
by brokenbetty » Mon Apr 13, 2009 11:53 pm
[quote="brokenbetty"]use a 2x4 stud where the bath screen will be[/quote]
Doh - I meant 3x4 of course
Liz
rosebery
by rosebery » Tue Apr 14, 2009 10:57 pm
"Doh - I meant 3x4 of course"
Doesn't change my answer.
brokenbetty
by brokenbetty » Tue Apr 14, 2009 11:22 pm
[quote="rosebery"]By the time you've boarded and tiled you'll have a fairly substantial wall to which to fix it. You'll be fine.[/quote]
Hi Rosebery - many thanks for your help :D
It is currently Sun Nov 24, 2024 11:04 am
