Painting over varnish
Crikey
by Crikey » Mon Apr 13, 2009 9:41 pm
I have a whole lovely wall of 70s style varnshed wood, sauna style.
I am reluctant to pull it down as I have no idea what is lurking underneath but quite fancy painting it.
As it's varnished what's the best way to prepare the surface? Do I need to strip all the varnish off or is there an easier way in this day and age of paints for every conceivable job?
Any tips would be gratefully appreciated. :D
rosebery
by rosebery » Mon Apr 13, 2009 11:08 pm
You will need to give it a really good and thorough sanding down and wash well with sugar soap and/or white spirit.
Then apply a coat of Dulux Ultra Grip Primer. Thi is a two part water based primer. You MUST prime BTW as paint doesn't adhere varnished surfaces very well. You could also use melamine primer.
Then decorate with a couple of coats of undercoat and gloss or satin wood.
HTH
Crikey
by Crikey » Tue Apr 14, 2009 10:42 am
Rosebery
Thanks for your help.
It's going to be a hard graft but thanks for all the tips. You're a star.
Cheers,
Crikey
It is currently Wed Nov 27, 2024 11:52 am
