Clay Sewer Pipe - connection to GU50 Gully Trap
oliveriles
by oliveriles » Wed Apr 15, 2009 10:31 am
I have a clay sewer pipe that runs under the path outside my house.
Currently I have a square salt glaze/ clay type hopper that allows me to see the sewer pipe and it also have a rainwater downpipe and two water waste pipes from the kitchen going directly into it from the top.
My building inspector says I need to put a trap gully in place to take the 3 water pipes.
My question is as follows;
If I put a UG50 bottle gully in place to take the three water pipes can the clay sewer pipe go through the UG50 pipe?
If not ok - is it ok to T around the gully and connect back to the sewer pipe on the other side og the gully - as the gully will also have to connect to the sewer pipe how far should this connection be from the gully trap?
If I do need to T what products are available to create the 2 90 degree bends in a clay pipe.
repys appreicated.
[/img]
It is currently Wed Nov 27, 2024 1:37 am
