MDF Window Board
Paul-E
MDF Window Board
by Paul-E » Thu Apr 16, 2009 3:26 pm
I want to fit window boards in conservatory using MDF. I have Bullnose MDF which is 290mm depth X 25mm thick The length being 12ft.
I intended just doing 45degree cuts on the ends to join to get L shape I need, however the 12ft lengths does not allow me to do this as they are 180mm short of length of conservatory so I would like to mitre the joints instead. I am experienced at mitre'ng kitchen worktops and have the router and jig and the confidence! Are there jigs available to mitre this width of MDF or can I get away with using the worktop jig with a few alterations of positioning?
Any ideas or suggestions would be appreciated.
Paul.
johnthejoiner
mdf window board
by johnthejoiner » Thu Feb 04, 2010 12:20 pm
if you have done worktop joints then use the same joint for this it will make a better job getting a mitre to fit perfect is awkward
chris_on_tour2002
by chris_on_tour2002 » Thu Feb 04, 2010 1:45 pm
i can't think of any reason why you couldn't use a kitchen worktop jig, the only problem is going to be keeping it secure enough to the small thickness and width of the material you are trying to cut. a job to be done on a bench i think.
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Mon Jun 28, 2010 10:03 pm
Discover how easy it is to find vetted and insured tradesman local to your area with the help of DIY Doctor. Visit our Find a Tradesman area: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Mon Nov 25, 2024 6:41 am
