DOT AND DAB EXTERNAL BRICK WALL THAT IS NOW PARTY WALL
RICKY FAIRES
by RICKY FAIRES » Thu Apr 16, 2009 9:09 pm
I WANT TO DOT & DAB AN OLD EXTERNAL BRICK FACE WALL THAT IS NOW AN INTERNAL BETWEEN HOUSES DO I NEED TO COVER WITH PVA?
THE EXTERNAL WALL IS NOW A PARTY WALL BETWEEN TWO HOUSES AS HAVE PUT ANOTHER HOUSE ON THE SIDE. I WANT TO DOT AND DAB THIS WALL HOWEVER HAVE NOT DONE THIS TO EXTERNAL BRICK BEFORE DO I NEED TO COVER WITH PVA OR SIMILAR BEFORE DABBING?
by stoneyboy » Sat Apr 18, 2009 1:54 pm
RICKY FAIRES,
Generally no need for PVA - adjust the workability of the adhesive to suit the porosity of the wall.
ricky68
by ricky68 » Sat Apr 18, 2009 8:08 pm
is the wall painted ,if so you will need to PVA first.if they are dusty bricks ie stocks or soft reds PVA.
It is currently Sun Nov 24, 2024 8:42 am
