Chimney lintel
lyons
Chimney lintel
by lyons » Fri Apr 17, 2009 10:01 am
We have removed the lintel from our chimney (what was a peice of wooden door frame or similar). Do we need to replace it with proper lintel? I would really appreciate some advice on this matter. I have picture of chimney if needed.
by stoneyboy » Sat Apr 18, 2009 1:59 pm
lyons,
If you are referring to the chimney hearth opening if the bricks above are laid flat you should fit a heavy metal flat to stablise the opening.
lyons
by lyons » Wed Apr 22, 2009 1:39 pm
[quote="stoneyboy"]lyons,
end[/quote]
Thanks - yes flat bricks. How thick does the metal flat need to be - will 20 - 25 mm suffice? And as we are installing a wood stove (the other question you replied to) - will it be ok to have metal lintel above?
by stoneyboy » Fri Apr 24, 2009 12:02 am
lyons,
Aim for something about 75mm wide and 6mm thick, the metal will be unaffected by the stove.
It is currently Fri Jan 10, 2025 4:15 am
