One of the radiators not getting hot
Biggolfer
by Biggolfer » Fri Apr 17, 2009 11:12 am
in the back bedroom i have removed a radiator and now the kitchen radiator is not getting hot, what do i nead to do to cure this. :(
plumbbob
by plumbbob » Sun Apr 19, 2009 11:22 am
I assume you have checked that both valves are turned on and the radiator is bled?
With the heating running, turn off ALL the other radiators in the house. The increase in pressure should shift the blockage.
by htg engineer » Sun Apr 19, 2009 7:29 pm
Did you drain system ?
Try turning off all other radiators and see if it pushes through.
htg
It is currently Sat Dec 28, 2024 7:55 pm
