putting a temporary windbreak up on a gravel drive
kathedwards
by kathedwards » Mon Apr 20, 2009 11:17 am
I want to put some holes in my drive so that when needed I can drop the poles on my windbreak in to give shelter from the wind. I was thinking of something along the lines of what you do with a rotary washing line. I need to be able to remove the windbreak each time after use. What would be the best method? The windbreak is 18 feet long
by stoneyboy » Tue Apr 21, 2009 10:51 pm
kathedwards,
Trouble is you will need to find specialist pockets to set in the ground. You could try driving in lengths of steel pipe but you need to form a sealed point on the end.
It is currently Sun Dec 22, 2024 11:52 pm
