Is a single skin boundry wall safe?
7 posts   •   Page 1 of 1
willintam
by willintam » Fri Apr 24, 2009 12:02 pm
Hi, I'm going to build a [i]rendered breeze block wall [/i]between the end of the fence and the side of the house to complete the boundary.
At the base of the wall (both sides) there will be a planter built in single breeze block. I will lock the planter walls into the main wall.
Can the main body of the wall be built as a single skin wall, or would it be unsafe?
The wall will be 2m wide and 2m high (from the foundations).
Also, should I tie the wall to the house?
Thanks for any advise offered
by stoneyboy » Fri Apr 24, 2009 10:46 pm
willintam,
Breeze blocks or aerated concrete blocks are not suitable for long term unprotected exterior use - use concrete blocks or bricks. Key the wall into the existing house wall for its full height.
You may need planning permission for a wall over 2m high - depends on the foundation level.
willintam
by willintam » Mon Apr 27, 2009 9:06 am
stoneyboy,
Thanks for responding. Unfortunately you did not answer my question "is a single skin boundary breeze block wall safe". It will be rendered and painted.
I know about the different types of blocks & foundations, I can't seem to find any advise about my problem.
Anyone help with this?
by stoneyboy » Mon Apr 27, 2009 11:31 pm
willintam,
I do not think any forum member will be willing to confirm that a 2m high breeze block wall will be safe.
willintam
by willintam » Tue Apr 28, 2009 9:51 am
I agree. After further investigation I have decided that it may well be unsafe. Pity it would just look and fit better. Cost saving was never an issue.
end.
bd3cc
by bd3cc » Wed Apr 29, 2009 11:06 pm
Where do you get Breezeblock nowadays?
I think that you would need to put in piers every 6ft, tied in to the wall for it to be anything like safe
willintam
by willintam » Thu Apr 30, 2009 8:00 am
Thanks for the replies.
The subject can now be put to bed as it's sorted.
End.
It is currently Fri Jan 10, 2025 3:42 am
