penetrating damp problems on my walls
glynn
by glynn » Mon Apr 27, 2009 10:51 am
Hi There
I seem to have a problem with damp on my interior wall on the gable end, in the summer when it rains but the air out side is warm i dont get any damp on my walls at all, but as soon as it starts getting colder outside and there is moisture in the air then this is when all my problems start with the damp.
I have tried using thompsons waterseals on the bricks outside but this doesnt seem to have worked.
Is there anything else that i could use on the outside brick to cure my problems, i thought of using bitumen or can you advise me
cheers
glynn
by stoneyboy » Mon Apr 27, 2009 11:48 pm
glynn,
The water seal should stop most of the penetrating damp (assuming you have applied 2 or 3 coats). Your problem is more likely to be condensation.
rosebery
by rosebery » Tue Apr 28, 2009 12:10 am
"Your problem is more likely to be condensation."
Agree and the answer to that is - ventilation!
glynn
by glynn » Tue Apr 28, 2009 11:18 am
Thanks for the replys, they have really helped me. i will give the wall a few more coats of thompsons and get more ventilation in the rooms
Glynn
It is currently Sat Feb 08, 2025 9:11 am
