Scandinavian interior doors?
dunkley01
by dunkley01 » Fri May 01, 2009 6:07 pm
I have a timber frame house with what appear to be factory prepared Scandinavian interior flush doors. The previous owner damaged one which I need to replace with a matching item. So far I have been unable to identify the doors or a UK supplier.
The doors are dark veneer (walnut?), 720 x 2038 x 40, with what appear to be standardised "snap in" hinges, each equidistant from the door ends to enable fitting either way up. There are two holes at the latch point, one for latch, one for lock/blank. These holes are central to the door edge so the door can be mounted either way up. The only clue I have is the latch face has the brand name "TrioVing".
Any pointers will be appreciated.
It is currently Fri Jan 10, 2025 3:04 am
