rewirable fuses in CU
s1bgs
by s1bgs » Sun May 03, 2009 1:59 pm
Hi all,
Would like to know what type the fuses are in my CU. they are rewirable plug-in / pull-out type. Are they 88`s 1361`s .... can ne1 tell me please.
thanks.
kbrownie
by kbrownie » Mon May 04, 2009 1:42 pm
Hi s1bgs,
The rewirable(semi-enclosed) fuse are BS3036
These will have a fuse carrier that will be marked with a coloured dot to denote the size of the fuse wire that should be installed.
BS1361 fuse are cartridge fuses assossiated to the type you find in a plug top. With again a fuse carrier much like the one above when used in CU
BS88 are more industrial and have a high breaking capacity, but are used as the main breaker at cut where your incoming supply is, this belongs to the eletrical suppliers.
KB
by sparx » Mon May 04, 2009 6:27 pm
hi,
rewireable= bs 3036
bs88/bs1361 are cartridge type fuses
regards SPARX
s1bgs
by s1bgs » Tue May 05, 2009 6:53 pm
Cheers all for your answers.
It is currently Tue Nov 26, 2024 9:56 pm
