Cold water tank
CREMATIST
Cold water tank
by CREMATIST » Fri May 08, 2009 3:33 pm
Fitting to water inlet works loose and leaks after a period of time.[/b] Flexi hose has been fitted to ball valve inlet, but still works loose over time . Vibration? Very small work space maybe not fitted properly? (2 x plumbers) Is there any thing on the market easy fitt?
steve the plumber
by steve the plumber » Fri May 08, 2009 5:55 pm
Sounds like the plastic nut is worn. Just visit your local plumbers merchant and get a new one.
by htg engineer » Fri May 08, 2009 7:40 pm
Renew fitting - Whatever that fitting may be.
Without more info you wont get much help.
Why does it work loose, never touched ? never knocked ? just comes undone ? pipes vibrating alot ? pipework clipped to stop vibration ?
htg
It is currently Sat Dec 28, 2024 8:56 pm
