cistern wont stop flushing
sasalan
by sasalan » Thu May 14, 2009 7:27 am
after flushing cistern, it tries to refill but instead the water keeps flushing through to the toilet. this leaves a constant stream of water flushing through to the bowl and doesnt allow the cistern to refill. have tried pulling the cable tighter which seemed to work initially but even that has failed now. it is a top flush (dual flush) cistern about 3 years old.
rosebery
by rosebery » Sat May 16, 2009 12:16 am
The float is too high. The cistern never stops filling because the float doesn't shut the supply off and never gets high enough to do so because the internal overflow comes into play.
Use the screw adjuster to lower the float.
I've no idea what you mean by "pulling the cable tighter".
bd3cc
by bd3cc » Sun May 17, 2009 9:11 pm
Could be that the siphon is stuck open
It is currently Wed Nov 27, 2024 5:31 am
