WIll downlighter bell housing cause fire to insulation above
conks
by conks » Sat May 16, 2009 12:16 pm
I'm to fit a series of spotlights in my kitchen.
The Kit is in a single storey extension, with a small roof void above filled with typical wool insulation.
I'm concerned that once in-situ, the bell housings may get hot and then set fire to the insulation/ceiling joists etc. ?
Can you confirm please.
Thanks.
kbrownie
by kbrownie » Sun May 17, 2009 12:58 am
Conks
Thermal Insulation is recommended to be at least 150mm from light lighting in ceiling void, this work is in a kitchen and needs to be notified to Building Controls or done by registered electrician or you are breaking the law. Check out project pages on Part P of building regulations.
KB
It is currently Sat Nov 23, 2024 1:16 am
