Security Light
ian00uk
Security Light
by ian00uk » Sat May 16, 2009 4:44 pm
i want to install 2 security lights with pirs outside my home which purchased from wickes (702839). which is the best way to go about installing them.it says about putting a switch inside so you can turn it off manually and to use 1mm or 1.5mm2 flexible 3 core cable. Also could you have both lights running off the same switch
Many thanks
kbrownie
by kbrownie » Sun May 17, 2009 1:00 am
Your on the right lines but it's part p look on projects pages for part P of building regs or get sparks in to do job.
KB
It is currently Tue Jul 02, 2024 4:04 pm
