Repair of Roof Verges & Valley
arryh
by arryh » Sun May 17, 2009 2:40 pm
I need to replace the cement on my roof verges and valleys. However early attempts have not been so good. Does anyone have a good cement mix and tecnique to make it easier??
Cheers!!
by stoneyboy » Mon May 18, 2009 9:53 pm
arryh,
A normal mortar mix 6:1:1 should work fine. If you are overcoating the existing mortaring the old stuff and surrounding tiles should be well wetted before applying the new - try to ensure you have enough depth to add at least 20mm thickness.
arryh
by arryh » Tue May 19, 2009 12:49 pm
Thank you I will give it a go in the next couple of weeks
Eelbuoy
Re: Repair of Roof Verges & Valley
by Eelbuoy » Wed Dec 07, 2011 11:56 pm
You want 3:1 for "flaunching " or " haunching" , quite stff mix.
Maybe even a shovel of sharp sand as 1 of the 3 , depends what you got lying about ; )
It is currently Mon Jan 06, 2025 6:15 am
