push button cistern
6 posts   •   Page 1 of 1
28mad10
push button cistern
by 28mad10 » Mon May 18, 2009 4:15 pm
have a top mounted push button cistern the problem I have his removing the top to gain access to the inside of the cistern, is the sleeve around the water controls just a push in hope I have explained my dilemma OK
bd3cc
by bd3cc » Mon May 18, 2009 9:15 pm
Likely to be screw-in I think.
Right hand thread so anti clockwise to undo.
28mad10
by 28mad10 » Tue May 19, 2009 5:14 pm
thanks for reply bd3cc, unfortunately didnot resolve the problem could it be a push in type bit reluctant to put to much force in case I do some damage it is an ideal standard may checkout their website, once again thanks for your reply
plumbbob
by plumbbob » Wed May 20, 2009 5:49 pm
If the cistern lid won't lift up, likely is the lid is screwed down.
Push down and hold one of the flush buttons. You will see a slight recess in the side of the other button that is now exposed. Insert a screwdriver tip and gently lever the button up. Repeat for the first button. You should now see a white plastic screw that when undone allows the cover to be removed.
Bye
28mad10
push button cistern
by 28mad10 » Mon Jun 15, 2009 4:12 pm
Thanks for your suggestion plumbob, my apologises for not replying sooner, unfortunatly it has not solved my problem no sign as far as I can see of any screws in the push button
plumbbob
by plumbbob » Mon Jun 15, 2009 10:51 pm
The point is the screw is hidden underneath the push buttons. The buttons have to be gently levered out to gain access.
It is currently Sun Nov 24, 2024 7:18 pm
