Changing from vented to unvented system - advice please!
Big Jim
by Big Jim » Tue May 19, 2009 7:55 pm
Hi, to cut a long story short, am going to change from a gravity-fed system to a mains pressure system, partly because I need to remove the existing gravity-feed tanks from the roof space, and partly because I need a new boiler.
I will only be needing a domestic hot water supply (ie, no central heating) and will need water for a kitchen, and 3 bathrooms.
Question: Should I get an on-demand boiler (multi-point) system, or have a more 'traditional' system with hotwater cylinder? And should I go for vented or unvented?
Any advice, information, or related comments welcome!
by htg engineer » Fri May 22, 2009 4:27 pm
"partly because I need to remove the existing gravity-feed tanks from the roof space, and partly because I need a new boiler."
Why ? to gain space or are the tanks knackered ?
If you stick with open vented you will still need the tanks - or new tanks.
Unvented your system will work off mains pressure - no tanks, just a cylinder. (probably the best in this case)
A combi would be pointless if you're not using the heating side, and a instantaneous water heater - would be the best bet - but not much good if you use more than one bathroom at a time.
htg
Big Jim
by Big Jim » Fri May 22, 2009 8:09 pm
Hi Htg,
Thanks for the reply.
I'm getting rid of the tanks because they were housed on the (flat) roof, which is being replaced due to multiple problems, and I would prefer to keep the surface as simple as possible so the tanks have got to go.
Having read this:
Google "gasapplianceguide.co.uk/Mains_Pressure_Hot_Water_Systems.htm"
I was under the impression it was possible to have a vented system that wasn't gravity fed... is that wrong?
It is currently Sat Dec 28, 2024 3:45 am
