by htg engineer »
Wed May 20, 2009 8:21 pm
Does it ever go higher than 2 bar ?
I would get the gas pressures checked by an RGI first, it sounds as though the gas valve is staying at high rate in CH mode, with DHW the heat is lost quickly - 0.5 rise in pressure is normal when the system is hot.
htg
