What size cable will a 9.5 kw shower require
drchris
by drchris » Wed May 20, 2009 10:48 am
bd3cc
by bd3cc » Wed May 20, 2009 9:32 pm
!0mm T+E
by stoneyboy » Thu May 21, 2009 10:48 pm
drchris,
Depends whether the cable is run in insulation - if it is 10mm is not enough.
If you have any doubts get a friendly sparky to confirm cable size.
rosebery
Re: What size cable will a 9.5 kw shower require
by rosebery » Thu May 21, 2009 11:21 pm
"What size cable will a 9.5 kw shower require"
Whatever your electrician says it will need. Its Part P twice - once at the consumer unit and once in the bath/shower room.
rosebery
"!0mm T+E"
How do you know that when the OP has neither indicated the routeing nor the length of the cable involved?
It is currently Tue Dec 03, 2024 8:41 pm
