External Tanking
Rocco
External Tanking
by Rocco » Thu May 21, 2009 11:47 am
I have bought a bitumen based compound from screwfix (AQUAPRUFE).
I intend to use this to tank externally below ground along my garage wall.
My neighbous driveway goes along adjacent to the garage and is higher than my garage floor.
This results in seepage through the brickwork onto the garage floor during rain.
The manufacturer instructions only call for sharp sand to be used as a protection on the last coat prior to back filling.
I am led to belive that a protection board will be required prior to back filling.
Can anyone advise on best protection for the bitumen coating prior to backfilling and where this can be pruchased.
NOTE :
My neighbours drive is approx 2 brick courses higher than my garage floor.
The garage wall DPM is just above the level of my neighbours drive.
jemball
by jemball » Wed Jun 10, 2009 11:26 am
Rocco,
I think Wickes do an Aquapanel water-resisting board which won't rot or warp, which I guess you could fix with instant-grab adhesive. You could also protect it with 4 inch blockwork.
Regards,
John
It is currently Sun Dec 29, 2024 7:39 am
