old floorboard
tooly
old floorboard
by tooly » Mon May 25, 2009 6:46 am
I have one floor board that has a bow across it's width. A fitted wardrobe is going to be built in this area and this uneven board needs changing. I need some advice. how do I remove this board without damage to others. The floor boards would have been laid during the 1930's so will i be able to get the same width size or will it be a metric size slightly different?thank's Tooly.
bd3cc
by bd3cc » Mon May 25, 2009 10:19 pm
Depends if is T+G. If so you will need to cut the tongue, and if it is not jointed where you want to remove it, cut down over the floor joists. A recipricating saw is ideal for this, and an electrician's bolster for lifting, BUT, be aware that pipes are always "notched" into the joists, and at a certain time, so were electric cables.
If there is a wardrobe going over it, and it will not be seen, could you not simply remove the offending area, or scribe the base of the wardrobe to fit?
tooly
by tooly » Wed May 27, 2009 6:51 am
Thanks bd3cc for your reply, I will consider both idea's. Tooly.
It is currently Tue Nov 26, 2024 1:02 am
